Removes addresses from the DHCP allocation table.
| vlan_name | Specifies the VLAN of the DHCP server. |
| all | Specifies all IP addresses, or all IP addresses in a particular state. |
| offered | Specifies IP addresses offered to clients. |
| assigned | Specifies IP addresses offered to and accepted by clients. |
| declined | Specifies IP addresses declined by clients. |
| expired | Specifies IP addresses whose lease has expired and not renewed by the DHCP server. |
| ipaddress | Specifies a particular IP address. |
N/A.
You can delete either a single entry, using the IP address, or all entries. If you use the all option, you can additionally delete entries in a specific state.
The following command removes all the declined IP addresses by hosts on the VLAN temporary:
clear vlan temporary dhcp-address-allocation all declined
This command was first available in ExtremeXOS 11.0.
